pedal swap done, almost
WhiteFizzo
85
Virginia Beach Va
I finally got the pedals in place. It was a major pain. Im going to button everything back up, but I have a connection that I can't find where it goes to. It looks like it should go somewhere on the steering column. Any suggestions? Also, on the 5 speed pedal assembly, where do I hook up the two connectors that are just above the brake pedal? The sensor is controlled by depressing the clutch pedal. Pics attached. Any help is greatly appreciated.
I would imagine that should be your neutral safety switch. The other connector should be on your wiring harness. Keep looking :)
