It came in the mail the other day after waiting 9 business days from AmericanMuscle.com. Downloaded the tune, which was 91 Octane, 4:10's, Offroad X Pipe, Chambered Mufflers. After downloading the tune I noticed my speedo was still way off. Being new to the whole tuning concept I went into the parameters of the custom tune from them. I noticed everything was set to stock along with the gear ratio. Spark was set to zero on all RPM ranges and WOT wasn’t touched either. Now I'm not sure if these numbers were supposed to look like this, but I knew for sure the gear ratio was supposed to be set to 4:10. I went ahead and set it to 4:10, re-downloaded the tune and the speedo was correct. I noticed absolutely NO difference in performance. I also noticed I could not turn off the TC or change to different LB injectors in the future. I then did some research and found out that the SCT Excalibrator SF is the one that allows the TC and injectors to be adjusted by the end user. I then called AmericanMuscle to ask them what was up with them advertising this adjustability with this tuner and they said it depends on the model car, which I immediately disagreed with.Super long story short, I had them give me a complimentary tune with the TC turned off and with 93 ocatne instead of 91. So for future reference, If you’re going to buy a SCT Excalibrator, make sure it is the SF version. It is exactly the same price, 379.00, but more features. Hopefully when I get the new tune I will notice a difference.
