I finally found and got a car to my house to start this. The first header is done. It wasn't as bad as I thought it would be over all. But it over was a pain. I did one tube over 4 times. Getting it from point A to B was easy. Getting it there with enough room for another tube to go behind it was the hard part.Believe it or not I haven't had to cuss yet. I have stared at the car doing nothing going on about 7 hrs now though.
So here's the plan so far. No hole in the fender required, but can cut on for cold air. Can run a sway bar. You can run AC OR PS, not both. AC should fit just fine without any mods. PS pump would have to move up and probably do custom lines. Probably something like the lines on a 5.0 bracket. Rack and pinion with also not be a problem,as well as any stick cars even with Z-bars.
Here are the requirements.
Battery needs to be moved
Cross flow radiator is needed
Alt needs to be mounted with pivot point in head.(Have only seen a few with in mounted differently)
The nice part is that most guys looking something like this already have all this.
64 and 65 guys, you have to switch to the stronger 66 and up motor mounts.
Any ideas, questions, suggestions ?
I've got 2 kits basically sold right now. I may do a small group buy with the mods OK to help some people get them cheaper and get these out there.
). What size down pipe and is it one piece to the firewall. It would be nice for that pipe to have a flange which will let you remove it to access plugs/valves if it is really tight there. Think plug wires will be an issue? Stock type radiator?
