I'm currently using the stock maf and injectors. How can I run a Pro-M 75mm maf calibrated for 24lbers but use 19lb injectors and not the 24lbers. I saw the different maf files in the MAF folder. I see "PROM_19" and "PROM_24". I'm confused on these, can they be used for my 75mm meter? They make different size meters don't they and they would have a different file for each size I would think?
2. Do I need to change the injector slopes or anything (right now I have the ones for the stock 19lbers....stock A9L calibration)
3. Any help with what exactly I'm going to have to do would be great....like what MAF file I will have to use and anything else I have to do.
....and then what I will need to do when I do put in the 24lb injectors with the 75mm meter (just run stock maf file and let the calibration in the meter take care of it or configure something myself
) if I do have to, do I need to do something with the injector slopes?
I've heard when you have bigger heads, cam, intake, tb to set both high and low injector slopes the same number as the lb. injector it is. Should I do this?
Thanks! Sean
) if I do have to, do I need to do something with the injector slopes? I've heard when you have bigger heads, cam, intake, tb to set both high and low injector slopes the same number as the lb. injector it is. Should I do this?
Thanks! Sean
