alright, provided i go with 05 wheels, would 245's up front and 275's out back work? also how can i up the stopping power of the svo set up other than drilled rotors and new pads?
so drilled rotors just help with dispersing heat and brake fade?
i was planning on going with the 94/95 spindles so i can keep the stock track width. is there anywhere where i can source the rest of this stuff? cuz the pick n' pull up where i am doesnt really have that many mustangs. so if i order that kit it will still look like i need
cobra caliper brackets(2)
caliper pins (2)
spindle to caliper bracket bolts (4)
94/95 spindles (2)
hubs(2)
hub nuts(2)
dust caps(2)
dust shields(2)
ball joint spacer or washers.330"tall
i think that should be it, where can i find this stuff other than junk yards?
Just need to decide on 94-95 spindles or 96-04 spindles.
If he goes with the 05+ wheels, then get the 96-04 spindles. Better suspension geometry and then will work better with the offset of those wheels.
Plus they are slightly cheaper than 94-95 spindles
brake lines? the kit from buyfordracing comes with lines i thought i just needed the adapter for the passenger side?
