MAJOR DOOR WINDOW PROBLEM HEEELP
dmaxstang
dallas
My windows go down all by themselves after about 3 seconds from shutting the car off. I have taken the key fob battery out already to see if it was malfunctioning and it still happens, what the hell? HELP quick its raining in Texas 3 or 4 times a day and for at least the next week the same thing.
if i recall, ther was a problem with the smart junction boxes getting wet in the rain, causing the windows to roll down. pull the pasenger side kickpanel off and look for moisture. i think it was caused by lack of sealer in the cowl.
Big Cat, here are the pics of that kick panel area, no moisture but it looks like a boot that goes through the firewall is opened up. Take a look.
and the area above the panel
Take a look at this video of exactly what i mean.
http://s57.photobucket.com/albums/g217/ghoststang/?action=view&current=100_1783.flv
You most likely have a SJB problem. In your PM to me I did not see those pics.
We have been having a lot of problems with these smart junction boxes, just the other day we had a brand new 07 that needed one before it was delivered to the customer
But you may want to try that tsb I told you about to see if it works before you bring it in to the dealer. here is the tsb
tsb said:
FORD: 2005-2007 Mustang
ISSUE:
Some 2005-2007 Mustang vehicles may exhibit issues with the functional power window features including one touch up, short drop, and bounce back.
ACTION:
Follow the Service Procedure steps to correct the condition if the root cause is incorrect or no window initialization of the Smart Window Motor.
SERVICE PROCEDURE
Perform a de-initialization procedure of the smart motor / side window glass, followed by re-initialization procedure.
NOTE: WINDOW RE-INITIALIZATION MUST BE PERFORMED WITH THE DOORS CLOSED.
NOTE: ON CONVERTIBLES, WINDOWS COULD BOUNCE BACK IF THE SIDE GLASS IS OUT OF ADJUSTMENT. REFER TO THE WORKSHOP MANUAL (WSM), SECTION 501-11.
NOTE: CHECK TO MAKE SURE THAT THE DOOR SEAL OR MIRROR SEAL IS NOT ROLLED OVER OR BINDING. ALSO, THAT THERE IS NO OBSTRUCTION IN GLASS SEALING AREA AND THE GLASS FIT AND/OR REGULATOR MECHANICAL FASTENING IS NOT LOOSE.
DE-INITIALIZATION PROCEDURE
De-initialization (un-learning) of the smart window motor clears the memory of the module and shuts off the One-Touch UP, Bounce Back and Short Drop functions.
The smart window motors can be de-initialized in two (2) different ways:
Disconnect the battery cable from the battery WHILE THE WINDOW IS MOVING.
Remove the window motor fuse from the Power Distribution Box WHILE THE WINDOW IS MOVING.
After performing one of the above procedures, the smart motor must be re-initialized, see Initialization Procedure.
INITIALIZATION MUST BE PERFORMED WITH THE DOOR CLOSED! (For convertibles, top and the quarter glass must be in the up / closed position.)
From the window switch, perform the following steps without stopping:
Operate the window UP and stall for 2 seconds. (Hold The Switch)
Operate the window DOWN and stall for 2 seconds. (Hold The Switch)
The smart window motor will be initialized and one-touch-UP and Short Drop will be operational.
Cycle the window glass an additional five (5) times to set the window "Soft Stop" for the down position.
TIP - VOLTAGE RANGE OF OPERATION: 9-16 VOLTS (AT THE MOTOR)
The smart motor will ONLY function in the 9-16 volt range; if the voltage at the smart motor drops below 9 volts, the window may not function properly or prematurely stop moving
If the voltage drops below 9 volts while the motor is moving, the motor will become de-initialized (one-touch UP and Short Drop will be inoperable)
If the motor becomes de-initialized due to low voltage, see initialization procedure. for instructions
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
062218A 2005-2007 Mustang: De-initialize, Then Initialize The Power Window Motor(s) Following The Service Procedure 0.2 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
14529 42
i would definately plug that grommet back into the firewall for a proper seal. ill ask svttech76 for some help on this one. :nice:
edit: :lol: mike replied before i did! guess we were all on the same page!
