- Oct 21, 2006
- 524
- 43
- 49
I posted this in the power adder section.
Maybe you guys could help!
What company, Nitrous Kit would you guys reccomend for my set up?
I would be using it at the drag strip only. 100hp to 125hp shot.
I'm looking for a safe kit and one that is easy to install that doesn't require any modifications to my set-up. I was lloking at the Zex dry kit ##82015.
I don't want anything that is going to wreck my motor.
Or should I try to get more horse power with a different cam?
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / Racing Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
Thanks
