What Nitrous Kit to Use?
93gtmustang
515
43
49
I posted this in the power adder section.
Maybe you guys could help!
What company, Nitrous Kit would you guys reccomend for my set up?
I would be using it at the drag strip only. 100hp to 125hp shot.
I'm looking for a safe kit and one that is easy to install that doesn't require any modifications to my set-up. I was lloking at the Zex dry kit ##82015.
I don't want anything that is going to wreck my motor.
Or should I try to get more horse power with a different cam?
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / Racing Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
i recommend compucar or nitrous express wet kits a wet kit is safer...these two companies do have a lifetime warranty on the product they sell that should speak for itself i dont know of anyone else who does this....i bought a used compucar kit off ebay and i love it and after contacting compucar they told me the warranty will follow the kit even if i buy it second hand i was sold....
http://www.compucarnitrous.com/
http://www.nitrousexpress.com/Pages/Home.htm
2 hours for basic..I went a little covert so I had some extra time installing due to my chosen locations for box and plumbing. The basic install is soo very easy and the 2 hours is mostly just putzing making sure everything is working and correct.
Nice. Any pictures by chance?
Here is the kit that I run. It is the kit for the trackheat/streetheat intake.
Very nice kit. I prefer this style of wet kit vs. TB plate or nossle style since the fuel can't puddle in the upper with the TFS plate kit. Its a little more expensive than the other kits but it works great and looks good too. Adjustable from 50-200 with the change of the jets.
