Your Stance!!
It isn't a mustang but its close enough
What year is that Falcon? I gotta get me one those!
grab-a-trac 620's 1" lowered in front, eaton gt comp leaf springs, 17x7 torq-thrust with 215 45 17 front, 225's rear...
Sonic blue looks awesome on your car man!!
I had my selection for paint narrowed down to 04 ford redfire and 04 ford sonic blue and I ended up going with the redfire
you should post a few more pics of that
the rear fenders are rolled, and the front, i cut the lip off, and stiitch welded a piece of 1/8 inch rod around the lip to stiffen it up.it seems the body on my car sits about 1/2 inch further to the left than it should:shrug: i had good clearance on the left side, but the right was way tight. i did both sides, anyway. btw, those are 225's on the rear, and 215's in front. i dont think anything bigger would have fit with the backspacing ive got (4.5) not on the right side, anyway...
does anyone have pics with the 99-04 bullitts?
Old thread, I know... but I just put 2003 Bullitts on (with 1" adapter/spacers) and wanted to add to the thread. This is with 1" drop 480lb-in front springs and 1" drop 200 lb-in composite leaf springs in rear. Tires are 225/45R17 in front, 235/45R17 in rear with no rubbing. Alignment is at +3* caster, -0.5* camber and 1/8" toe:
Before the Bullitts, the car looked like
Daniel
Front wheels:
Magnum 500 in 15x7"
205x60/R15
Rear wheels:
Magnum 500 in 15x8"
225x60/R15
Front suspension:
Complete Global west tubular upper and lower control arms
1" $helby drop and slightly chopped spring (half a coil I think)
Rear suspension:
4-Leaf mid eye leaf springs
