92 GT Motor into 70 w/ 4spd toploader
mmorningstar
15
okay posting this question for a buddy, I'm currently a fox guy, so I figured I would ask the guru's in the old school tech section.
My buddy is swapping a 92 302GT motor into his 70, he is staying carbed, etc, just switching motors for a new(er) rebuilt one. The car is a 1970 Mustang with a 4spd toploader, it's a 302 car so the shaft is the right size, and it looks like it will bolt up, but his dilemma is the clutch. The stock 1970 is a 164 tooth flywheel and the 92 motor is a 157 tooth flywheel. So what clutch does he need? And will he need anything else?
Thanks!
Matt
He needs a 164 tooth flywheel, however the imballance is not 50oz on the old motor so he will either need to get another flywheel or have a good machine shop change the imballance on his existing flywheel. Also, there is no provision on the 5.0 motors for the mechanical clutch linkage. I think NPD sells an adaptor bracket for this.
1.) My buddy is swapping a 92 302GT motor into his 70, he is staying carbed, etc, just switching motors for a new(er) rebuilt one. The car is a 1970 Mustang with a 4spd toploader, it's a 302 car so the shaft is the right size, and it looks like it will bolt up, but his dilemma is the clutch. The stock 1970 is a 164 tooth flywheel and the 92 motor is a 157 tooth flywheel. So what clutch does he need?
2.) And will he need anything else?
1.) He can use a 10.5 or 11" clutch with the 164t flywheel. In order to use a 157t flywheel(for whatever reason), a 157t-specific bellhousing is needed to put the starter in the right place. If the flywheel is a stock 164t early style, a 3-finger clutch can be used. I'm relatively sure the T5s and Toploaders use the same disk in case a diaphragm clutch is needed.
2.) Yup, he'll also need one of these:
It's that little bracket hanging off the scattershield where the stoc z-bar pivot used to be. 5.0s blocks don't have that provision on the block itself like the earlier engines.
thanks so much for the input guys, it helped us out a lot as far as pointing us in the right direction. It is very appreciated, especially to the guy that attached the pics. thanks again! -Matt
