BlackVert
How does that work w/ getting exhaust from only one side?
Alright, spent $19 dollars on a tap and got the pan tapped and the fitting in and thus the oil return line is now on. I filled up the coolant, oil, and got some gas since the tank was empty. Go to start it for the first time and nothing. Doesn't even crank. There is power to the starter because is sparks when I touch a wrench to the postive connection. I need some help guys. Is the starter maybe bad or a ground not connected? Any other ideas as to why it wouldn't even crank?
Thanks.
Other han paving roads with rubber.how much did you spend on this turbo setup??
i'm looking into turbos myself but i'm looking at HP performance and what apears to be about 5K to get everything i need, (injectors, etc,etc,).
what about fuel system? what pump(s), fuel lines, rails,
how much air will that turbo push not just psi, how much are you going to push?
i want about 500 rwhp and 500 rwtq myself?
are you using a blow through maf or a regular one?
I'm sure i can think up some other stuff but i'll stop here.
looks awesome btw![]()
i'm jealous![]()
check your grounds to motor.![]()
nice setup and what do you expect to make with your setup???Other han paving roads with rubber.
Very nice build man, after building my twin turbo setup, if i ever went turbo again i would go with a big t-70 single like you did. Very clean, and i know how much work something like that is.....impressive. I might have missed it, but what are you doing for MAF, fuel and what a/r turbo are you running?
yes....3.27s were a HUGE improvement over 3:73's......first gear was useless and wouldent build decent boost till 2nd.
I realized when i was going up a hill in 2nd, floored it, and was amazed what the added load did.
I still have my 3.27s and even though my car is slow N/A, i really enjoy being able to cruise on the highway.....plus they will be nice for my kenne bell!
