- Oct 21, 2006
- 515
- 43
- 49
I went for my inspection today. I was hoping that I would pass emissions with my new motor and cam. They wouldn't even bother to do an inspection at all. They said that the state is getting tougher on sound levels. I have Flow Masters that are not new, and running 2- cats. Too loud they said. I asked if they have a set decibel level that you can't exceed. They said , it's a judgement call. That's not right. I went to 3 different inspection stations. There are pick-up trucks and Harley's around here that are way louder than my car. And the sad thing is, I only put 2000 miles on my car last summer going back and forth to the track.
It might be time to get a tow bar and make it a full out drag car.
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
Obviously they don't log the sound level anywhere so it's up to the inspector as to whether or not he feels like being a dick/sticking to the rules 100%. I failed years ago w/just a catback (stock H-pipe, headers, and engine) thanks to the inspector going by loudness only (didn't even put me on the dyno to run the sinffer). And naturally, years later w/the heads, blower, H-pipe (w/cats), headers, etc. etc. I passed with flying colors on the sniffer. It allllllll depends on who does it as far as sound goes.
