331 Stroker Kit ?
FATLS01
hey guys what up ? I am tearing down my motor in the garage and would like to make it a 331. i plan on using nitrous, 125-175 shot. stock heads and aftermarket upper and lower 70mil tb. should i get the kitt from dss or chp ? and what size MAF and injectors should i use ?
either one will be fine. they are built basically the same. and with stock heads 19's will be fine. the only thing im not sure about is the addition of fuel with that much nitrous.
You may want to add some heads (cheaper than stroker kit and machine work/assembly), with more power to boot.
Then just trim down the NOS shot a bit, and you are good to go.
