C4 swap ???
GTCobra90
29
I am taking out my TKO and putting in a built C4. im in need of a belhousing but summit sells two different depths of housings. does anybody know which one i would use or can anybody help me figure out what to buy.
Thanks guys
depends on if your trans is case filled or pan filled for the dipstick tube. usually smaller bellhousings take the case filled and the larger use the pan filled bellhousing. do you have a flexplate yet? the 157 tooth flexplate will only work with the small bellhousing unlike the 164 Aod/large C4/C6 type. just a few things to look for.
count the number of teeth on the flexplate. if its 164 you need the large bellhousing if its 157 you need the small bell. is the flexplate you have from an Aod or is it the C4 swap flexplate for the 81up 302's ?
edit: i forgot you said you have the case filled trans. you will need the small bellhousing. i highly doubt the large will work because of the dipstick tube being in the way. for that you would need the 50oz 157 tooth flexplate. ebay has the flexplate for like 39-49 bucks . heres a link to the flexplate if you go that route http://cgi.ebay.com/ebaymotors/_Car...diZ2865QQcmdZViewItem?_trksid=p3756.m20.l1116
