Looking for some helpful advice. I installed a Steeda 3-1/2 tapering to 4" aluminum driveline on my wife's 2007 Mustang. The car has been lowered with the Ford Racing spring kit, approx 1-1/2". Under hard acceleration in 1st and 2nd gear the driveline rubs the underside of the car (tunnel) It is NOT rubbing the emergency brake bracket, but the bottom of the tunnel.
I have installed Steeda Lower Control arms and an adjustable upr 3rd link.
The Upr link is set at Steeda suggested 8.36" dimension for performance use, Still the rubbing persists. With drag radials at the track it is even worse. The car squats a lot under hard acceleration. Anyone make rear springs that are stiffer than Ford Racing. Eiback and Steeda say their spring rates are the same as the Ford Racing springs.
I am thinking about going to a 3-1/2" driveline. Anyone know what HP a 3-1/2 can handle?
I need to figure something out, because as I said, it is my wife's car - ya know what I mean.
her car at Horsepower Ranch, and Wednesday dyno-tune my 65' at Blood Enterprises (need to work out some bugs) then that evening we are going to Pacific Raceways to see which of us has the fastest Mustang. I'd love to puff up my chest and tell the little lady how things are, however, I not only have my doubts of which car is quicker, but she has turned into quite a racer. In the CCCA racing series, Sue is tied for 2nd place in points at Pacific. If that nonesense keeps up, she is going to be tough to live with.
You added power, and you added diameter to the rear of your driveshaft and you're surprised about clearance issues? Granted torque arms tend to lift the chassis under acceleration, if your driveshaft has a higher diameter than is stock, it makes sense that you have rubbing issues. Either way, having something with a greater diameter means you need more energy to spin it: bad idea.
