FYI, my car:
Mustang 86 - Mach1 Springs
1986 Mustang
Mach1 Springs, Steeda 1/4" front spring spacers (placed on
top of the isolator),
BBK poly top & bottom isolators, new Fox FCAs,
Tokico 5-way adjustable struts (set on 4 out of 5).
The front fenders sit ~26-7/8" from the ground
and that's with 245/45/17 RE730s (@32 PSI) which are the correct diameter for the car.
The Mach1 springs are rated at 600lbs/in vs the 425/530 lbs/in stock GT springs.
Also: MM Caster Camber plates, MM bumpsteer kit,
STB, subframes, M2300K Cobra brake kit, ABS, SS brake hoses,
poly swaybar end-link bushings, poly swaybar bushings, heavy swaybar end-links, etc.
