running bad at wot 3500rpm.....help
alright i'm done throwing parts at it .......
Need some help PLease....
88 gt 5 speed stock short block upgraded to 89 cpu harness and a9l/ maf
cleaned all grounds to shiny metal and a touch of dielectric grease too..
idles at 650 -700 steady
new : wire,cap rotor plugs
gt40 -p's w /1.7's fresh and just installed
arp head studs
exploder intake
255lph fuel pump stock afpr 40 psi vacumme off,,,, .
24lb injectors w matching pro-m 80mm maf cali.24s/c
70mm throttle body
10* of timing [spout out]
timing set - set up to [0]
water pump
taurus fan w/ dcc controller
fuel filter
tfI module
tps
soaked the injectors for 3 days in chemtool b-12 and blown out with compessed air backwords then reassembled with new o-rings filters and pintle caps....
sprayed carb cleaner all over engine and vac hoses and connections and it made no difference in idle... has 17 in at Idle and 22-24 when accelerating....
pinched off the fuel return line and fuel pressure goes to 100psi very quickly and engine starts to die......
pinned out maf and connection tested within spec
tps is set to .970 volts and sweeps to 4.5 volts as you go to wot
no check engine light while driving...
now here are the codes from the koeo:
522 vehical not in park or neutral
552 ??? airbag module ????
565 canister purge failure
558 egr vacumme reg failure
542 fuel pump secondary circuit failure
Has a stumble at 3500 like someone turned the key off then comes back to life ...misses hesitates runs like crap at wot but if you ease into it will pull to 4500 then does the same crap........ also after this happens and you get out of the throttle backfires out of the exhaust one time then it seems that at a steady speed below 3500rpms like its dropping a cylinder or two and then clears up..
granny it around and you wouldn't really notice any of this....
changed the injector harness pinned it out before installation(tested good) and its still the same....
egr and smog stuff has been deleted I have the bullit plugged into the egr plug....
exhaust seems noticably warmer on the driverside when feeling at the tips
This car has set for 2 years being only started and let warm up a few times
now when this was converted to maf and I didnt get the plug all the way into the firewall and after spraying out the engine bay water filled up into a square ecc relay near the cpu it was hanging out just below the heatercore shroud area by the pass kick panel and was full of water and I had to replace it to get the car to run after the head install....
Need someone to help me figure this out...
gonna ground out pin 30 on the ecc and do the koer test today.....
and I have read posts for two weeks trying to find a cure, it seems the ones that have had this problem fail to post up what they have done to cure the problem.....
arp head studs
exploder intake
70mm throttle body
water pump
fuel filter
tfI module
tps
