So you do have to use a spacer for the balancer? Thanks for the heads up on that, I've heard from some people that you do, and that you didn't from other people.
Keep it up!
well by spacer on the balancer i mean after i put the balancer on i will need to make a spacer to put on then the crank pully. I'm usong my under drives from my 5.0 so that could be why? if you look at the first few pics i posted when i started you can see how long/deep the stock 351 crank pully is! if your far enough along i could make you a spacer when i do mine? just give me the amount of spacing you need, i will machine it out of alumn as long as we have the thickness at work you need.i also might make my own fuel rails so if you need them let me know also.peace
john
