- Aug 7, 2004
- 366
- 0
- 17
I have an autometer wideband air/fuel gauge with bosch wideband sensor can i just remove one of the o2 sensors and install the bosch sensor? Like one of the aft sensors? Thanks.
Brian - Do you happen to know why it's preferred to have the sensor before the cats? Is it related to how quickly the sensor gets hot or how hot it gets? I was told that the reading would be off if it was after the cats but I have reason to doubt that.
I would think that an accurate reading of what happens during combustion has to be made as close to the engine as possible and not after the cats because their filtering of gasses and particles would alter AFR readings.
Correct.....the closer to the source you can locate it, without overheating the sensor, the more accurate the measurement will be. Installing the sensor after the cat will result in "leaner than reality readings". Also, the sensor should be mounted at the top of the exhaust pipe between the 10:00 and 2:00 position at the top of the exhaust stream. Mounting it below these angles could result in condensation accumulated on damp days, or short trip cool down leaking back into and damaging the sensor.
