ebay rims
Stang_1973
565
9
38
San Antonio, Tx.
http://cgi.ebay.com/ebaymotors/17-17x8-17x9-POLISHED-NEW-WHEELS-RIMS-FIT-MUSTANG-1973_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem220362130362QQitemZ220362130362QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Found these on ebay. 17 X 8 fronts and 17 X 9 rears. they claim to be direct fit on 64 - 73 mustangs. Anybody used the before? You think there will be any fender clearance issues? WHat size tires would work best?
BTW these would be going in a '73.
They also come in 17 X 7.
They look like Chinese knock-offs of Torq-Thrust 2's, so they will fit 17x8's with 4.5 BS is fine and it has the correct bolt pattern. Although I believe for the fronts you may want the 17x7s, but plenty of more people will chime in for sure.
They are probably 1 piece (instead of 2 piece like real TT2's) and are probably noticeably heavier. But they are a great price.
I put these exact rims (17x8 front and 17x9 rear) on my 70 sportsroof, but with the gray color. I went with 245/45's on the front and 275/40's on the rear. I initially had a rubbing problem, but that was attributed primarily to the old (read original-minus shocks), sagging suspension. New leafs in the rear fixed that problem and i am currently putting coil-overs on in the front. I am not anticipating a problem there either. Once i get to do some hard driving and see how the end result performs, i am considering rolling the fenders to provide a little more clearance. i can post some pics if you want.
i'll post some more pics here in a minute. Overall, I was very impressed with these rims. The finish was smooth and without any flaws in the coating. I am unsure of the weight of these, but they are probably a bit on the heavy side... but i guess that can be expected for the price. I have driven with these rims on now for about 7 months and do not have any rusting or pitting anywhere on these.
we bought a set of 15x7 and 15x8 from them instead of the larger rim size,. Finish is excellent, and they are a one piece wheel. the only slight problem we had was a standard deep 13/16 socket was a little tight, simply simply ground the socket down about .025" and everything went well. We will be posting some photos soon on the progress including the wheels. the company is in Souther California and we were able to pick them up.
Hey Cavboy 78. Had another question with the rims. Where did they rub at in the rear? I
bought a set of 1 inch lowering leafsprings and Im wondering if I might have some problems
with rubbing with the same rim and tire combination.
Thanks for the help
Steve69
