New suspension in the way, lose the side exhaust?
can u weld/fab yourself? you could take some exhaust pipe and flatten/widen where it needs to go under the subframes to give u some clearance
Made it work!
I want to thank all the peeps that encouraged me to keep the side exits, it really wouldn't be CobraRed's stang w/out em. I guess spintech sub frames it is when i do the engine build. And to the haters, suck it:fairyfight: (jk, i love you guys).
Polished the tips then the pipes were recut.
Took a chunk out of the after muffler bit and brought it forawrd
New clearance:
Sits now:
Just go to a decent exhaust shop. They can take care of that easy. It needs to be a good place though. Ask around for someone that does custom exhaust work and that'll be a breeze.
Boo, no subframes :)
BTW, when I put the PHB on my old car, I simply removed the piping from the muffler back from the Bassani's. There was no increase in odor in the cabin, and it actually got a bit quieter until I got on it. I liked the sound without the pipes better than with the pipes.
I can fit Spintech subframes in there - it just wont be l33t. And it probably sounded better because it was exiting so much closer:p. I wasn't worried about odor either, im used to the tips being right below my window.
Keep the side exhaust man , there's got to be a way to make it work. You may check out Dr.Gas they've got some different styles of tubing that may work for you. I just hope I don't run into this with my side exhaust. BTW , I didn't know spintech made SFC's ?
