Hey so on my 347, with Trick Flow top end, with powermax 2030 cam, I am looking to replace my 65mm TB, Cold Air Intake kit and 70mm Mass Air Meter said to be cal. for 30lb injectors which I have for a 75mm Accufab TB, 4 inch anderson power pipe, and a velocity PMAS MAF cal. for 30lb injectors.
So first thing I am looking to get is the Throttle Body, It says the Race version of the throttle body has the 4 inch opening so I am thinking I want to go with that version, but still want to run the 75mm EGR Spacer, while keeping the EGR system functional rather than switching to a blank spacer. They offer the regular EGR spacers from accufab that are 75mm, just wondering if I will run into a problem using the 75mm race throttle body. Only difference is that it doesn't have that Vacuum Line on the TB.
Just wondering if this will cause me any headaches. Any opinions about this? Thanks!
