I was wondering how much hp will be produced at 6-8 psi. I have been told that I am making about 300 right now. I read that an AOD can handle about 350 and I didn't want to push it right now.
My general rule of thumb for a pushrod 302, is about 25RWHP for every 3psi provided tune is good and cam is proper.
If your going supercharger I would recommend 3.42 or 3.73 over the 4.11's. You'll be out of gear when the charger gets happy.
umm i would say its closer to 50 rwhp for every 3psi on a typical H/C/I 302 cause most guys get about 500 rwhp out of 12 psi.
+1 I would have to say 3.73, I run out of gear way to quickly, I believe there is a 3.90(somewhere in there) would probably be good for the auto. 4.10s with the supercharger may spin alittle to much.
50 is waaaaay to optimistic especially if you're running an anemic street blower.
so your saying a H/C/I 5.0 with 12 psi should only be 400 - 425 rwhp? i would burn it.
When I do get the sc I will research into a cam and other parts. I was just worried about the tranny. It sounds like I should upgrade the tranny before I get the sc.
