gasket for sunroof?
Do you have to acctually remove the sunroof or can it stay bolted on?
you do know that the sunroof is removable right?
its not bolted in, just hooks into the roof.
Take the sunroof out and blow out the tubes in the 4 corners with an air hose. should stop water build up. be careful not to use too much force as you can accidentally detach the tubing from the nipple.
