do they make a gasket for the sunroof latch where those two bolts go through? i siliconed it when i put the new body to sunroof gasket on last year but it seems like im getting a small drip
thanks
you do know that the sunroof is removable right?
its not bolted in, just hooks into the roof.
Take the sunroof out and blow out the tubes in the 4 corners with an air hose. should stop water build up. be careful not to use too much force as you can accidentally detach the tubing from the nipple.
