- Dec 17, 2009
- 8
- 0
- 0
Hi Guys,
A question that may test a few allegiences.... I'm in the UK and have a low miles, '96 Cobra, stock other than being 2 inch lower on eibach springs.... i've just been offered a 1990 Fox LX with a Vortec bolted on... spec is as below, i'd be interested in opinions, how much can the 302 handle with stock internals, can the trans. handle the power? I think they've got T5's in them right? The gear head in me gets a hard on when i hear words like supercharger etc etc and i'm sure I'm not the only one!!! Anyway email is below, opinions please, and thanks in advance:
Best wishes, Saul
Hi Saul,
The car was mostly modified in the States, and although i don't have a dyno sheet, i got the numbers from the paper work that came with the car.. but i can safely say that judging from the other cars i've been around it seems accurate, this is a very quick car.. paper work says 420hp/380lbs torque @4000rpm
Modification are..
Vortech V1 supercharger making 8psi boost
B303 Blower Cam shaft
76mm C&L Mass Air Flow/ 30 lbs injectors to match
67mm EGR spacer
High flow throttle body
JBA adjustable fuel pressure regulator
Hi flow in-tank fuel pump
GT-40 upper and lower Hi flow Intake Manifold
Roller Rockers
TFS Heads
JBA shorty Exhaust headers
Limited slip, 3.55:1 Gears with an LPW Ultimate 8.8 Brace Diff Cover
Hurst Shifter
Transmission is a 5 speed from a 92 mustang as they have stronger internals
Heavy duty Desert Cooler Rad
Eibach Sportline Springs
Mileage is 68000
Best wishes, Saul
Hi Saul,
Modification are..
67mm EGR spacer
Roller Rockers
TFS Heads
Hurst Shifter
Mileage is 68000
. Curious about that Hurst badge on the back.Anyone enlighten me?
