StangNet '11 5.0 Notch Project
I designed the pedal to place the new 2011 pedal in about the best and only position. I plan to have these produced for people doing the conversions as well as could be used in any vertical firewall application. This pedal is not designed to be mounted on a vertical surface.
What are you putting your engine in? Is the factory pedal mount stud locations in the exact same place as the FOX pedal? I have one left from the first batch I could sell you if you need it.
Mike
Man are we so close! The only thing really left is to get the power steering sorted out and I don't want to bother with details but it has been a pain. Solutions are in the works so hopefully have her on the street in less than 2 weeks.
I pretty much buttoned up the interior today.
Swaybar remains an issue but will not prevent us from driving BTC. The location of the alternator on the new 5.0 is just in the way... period! I heard today some think it will also hit the power steering pump if you use the Ford Racing bracket (which you cannot get now as its been pulled for updates). We are working with J&M and will probably have to design a swaybar for these swaps.
Hop on over to blog.fox50swap.com for some more pics and updates.
We ended up designing our own, as there were not any real options we liked. We plan to switch to the KRC setup in late August to allow for A/C but this bracket works nicely in the A/C location. We will probably produce these with a production run soon for those that are interested.
The Alternator is still in the way of the swaybar and this pump location will also interfere in early FOX's, so we are working with J&M on a blade type swaybar.
attachment.php
attachment.php
The entire wiring harness has been scrapped from the car excluding the rear tail light pigtails and front light pig tails. We have installed the ISIS power management system. Some exciting things we are going to be able to do with this system for sure. Details to come.
attachment.php
BTC Update: ISIS Power management installed - StangNet' Built to Cruise
ISIS Intelligent Multiplex System - Automotive Wiring Harnesses, Car Wire Harness, Engine Wiring Harness, Auto Wiring Harness, Truck Wiring Harness, Car Wiring Kits
Any update on this write-up? I'm very interested in the kit and would love to see some sort of walkthrough/overview about the whole setup.
Yes I need to do this! The summer got hectic and HOT so I have not progressed on the details like I would have liked.
I plan soon to do much more documenting.
Mike
Thanks Mike. No rush, I'm just very intrigued by the kit/your install.
I might shelf my 363 plans for another project and go with the Coyote on my next car, thanks for keeping up on the thread.
One question: aside from the bolt/mounting hole massaging, the only thing you had to do in order to mate the hydroboost to fox pedals was raise the connecting pin 1" center on center?
Joe
