Where does the fuel injector get it's signal from?
Well, if you've seen my other thread, you'll see I'm in search of a fault in cylinder #3.
http://www.stangnet.com/mustang-forums/842247-misfire-woes-i-need-help-please-read.html
1995 Mustang GT 5 Speed. Completely Stock.
I'll be placing a test light at the injector harness and checking for the injector pulse. I'm curious to ask, does anyone have any information on what the pulse should look like? I'm assuming the pulse should look similar to a timing light?
Also, where does the injector get it's signal from? I'm assuming the injector gets it's signal from the ECU.
Thanks for all the help and opinions so far!
Yep regarding the flash. An LED test light or noid light is best because of the dwell control.
The injectors get constant accessory 12V, and each has its own modulated driver that comes from the EEC, as you noted.
Hissin, so you're saying it gets a constant 12v, the switched signal is the ground?
You've got it. If the noid light does not flash like a timing light, do a continuity test on the wire. If the noid light is on solid, look for the driver (ground) wire being pinched between metal parts (and shorted to ground, thus exciting the injector constantly).
Yeah, I got a hold of a noid light and will be using that this weekend. Also, question for you. The ground appears to be a red wire, for all the injectors. I'm wondering how they are switched? Also, sounds like the ground retuns to the ECU. How is the ECU grounded? I'm thinking I might have a bad ground somewhere... I guess I gotta get a hold of a wiring diagram to see how it's switched and so on...
Update:
Found this:
So if I'm seeing this correctly, brown/yellow is suppose to be the switched ground for the injector? Looks like the red wires are hot at all times.
Hmmm... interesting.
Red is the power to the injectors. Brn/yellow should be the ground for injector 3. Remember, they share accessory 12 volt power but have individual grounds from the EEC.
The big EEC ground is below the EEC in the kick panel. This is not where I'd be looking since only one cylinder is apparently affected.
Remember, you can have noid light "pulse" or flash and still have a bad injector (pintle failure) so check that injector with a tester, stethascope/long thin screwdriver compare to others, it should "click" each time it's energized and that means grounded by ecm, common failure in EFI cars.
Yeah, that's true. If only one is affected, then the brown/yellow wire is the one I should be worried about. Also, when I last put a volt meter to the brown yellow wire, it was reading battery voltage. Tell me I'm wrong?
I have a stethoscope at home, I'll grab it and check it. I forgot about the sound test.
Thanks for the info guys, some more opinions would be great!
The ground-side can show weird things with a meter because of the involvement of the EEC, injector coil, and hysteresis in the DMM. The noid makes it easy.
Looks ok to me.
And the test with both looked very symmetrical to me. If that result is good enough for cylinder 2, it should be good enough for number 3.
Looks ok to me.
in person the light output seems VERY low in person. I still think I have a ground issue, because I highly doubt I have a full 12v at idle. I'm curious to think what if the shortage in voltage is causing an issue with the electronics. I'll be running my own grounds today and see if that helps.
Ok HISSIN50, Harvey and I just checked the car again. We added two new grounds to the system, one to the accessory bracket near the idler. One at the factory point on the block near the oil pressure sending unit. She ran the same, although I did notice a steady voltage. I planned on better grounds, so I will keep them... So Harvey and I were thinking, maybe recheck the timing on the car. I think we may be getting closer to finding out what is going on. We removed the spout and started up the car, and AMAZINGLY ENOUGH! The car is running GREAT!!!
We turned off the car, and put the spout back on, and it was running really bad. Seemed to miss and the car just didn't seem right.
On one of the cylinder balance tests, there was a code that came up. The code was for A Ground Issue with the spout. We blew it off thinking that it was just because we ran the car without the spout connected. It looks like it was trying to tell us something. What do you think? Ever ran into this before??
