Build Thread 1967 Dynacorn Fastback
We removed all the suspension now it goes on a cart to prime and finish all the the bodywork
Rusty - THANK YOU THANK YOU THANK YOU!! For posting how the vent windows didn't fit. With my level of inexperience, I didn't give it the first thought that the vent window wouldn't have fit. Well, guess what? Mine didn't fit either... took some major minor surgery to get them right, still not perfect, but I think they will work. Driver side was so bad, it even changed the alignment of the door, I will have to touch up the body filler on back edge of door wear it feathers into the rear quarter. If I would have had to do that after paint, I would have had to get the doors repainted and I would have been livid! Again, THANK YOU!
To the OP. Do you forward all this stuff to Dynacorn? They should fix these problems before the sell one more of these bodies. I can understand a problem or two, but these issues you have posted are on the line of unaceptable for the cost of these mustang bodies.
Read all about the under dash hood release install in an upcoming issue of Modified Mustangs & Fords magazine.
We have been working on getting the fenders, headlight buckets and doors to line up
The body was sanded down to bare metal and the next step is spray 2 coats of SPI black epoxy
The rear valance had a tack weld and also bolts.
Instead of studs on the valance Dynacorn used 2 different size bolts and washers from inside the trunk and attached to clips on the valance
We wanted to take off the rear valance to see what was behind it and just as I thought bare metal and surface rust
We now have a new helper in the shop and he was busy sanding down to bare metal
I sprayed two coats of SPI black epoxy yesterday
Block sanded the hood and doors
Sprayed one coat of SPI black epoxy to seal than sprayed 2 coats of Slick Sand Polyester primer
The shipment from Dart came and now our engine builder Mike at Competition Motorsports in Sarasota Fl will be busy.
So after a long hiatus from the Mustang community, I'm finally coming back. I bought a 67 fastback a couple months ago and I have to follow this thread! My car is going to need much rust repair, but I'll enjoy following this build because I've always been curious about these car bodies. Badass so far, and whoever said "that's why we're here, to learn!" hit the nail on the head. I can't tell you how much I learned about cars back in the day (7-10 years ago) on THIS site!
Lot of block sanding
Couple coats of SPI epoxy
The owner sanded the interior and undercarriage himself.
This is how he looked after sanding
Sprayed a couple coats of SPI red oxide
Fitting the roll bar
Fitting the trim panels
Sprayed the bottom of the deck lid and hood Acapulco blue
