Hello, people, i Just Joined this Community tonigh 12/03/2013 at 7:40Pm
My problem:
I have a (1999 Stang, V8) (after 3 years with no problems)Stock heads where messed up by Cyl#3 .. I REPLACED heads for semi-new(1,200$ 1 year ago) Before putting heads back, Mechanic ADDED some special HELICOILS that where installed before final installation so that it will have more thread and it will avoid getting another spark plug blown. After installation (1 year later 10/12/2013 ) Cyl# 5 decided to break, I sent it to the shop for Helicoil job...
, Today 12/3/2013 Cyl#3 is misfiring, i turn the car on, and i can feel the low compression, i use my OBD2 machine and Cyl#3 is back again after so long..
My Questions:
Can i add STRONGER HEADS with STRONGER SPARK PLUG THREADS to my stang?
Can i add cobra heads to my 99 stang?
Where can i get an upgrade for this FORD HEADS Typical problem?
I live in CA Inland Empire Close to L.A...
Any advise or comment is welcome, negative feedback, just leave it for later.. THANKS in advance
My problem:
, Today 12/3/2013 Cyl#3 is misfiring, i turn the car on, and i can feel the low compression, i use my OBD2 machine and Cyl#3 is back again after so long..My Questions:
i was looking into that, but would it work in a head that was already using a helicoil.. is it possible to reuse the same hole after being use with a helicoil...
