1999-04 Mustang V8 4l Misfiring, Replace Heads Or Not?
Which 99 stang heads are better than stock ones and why?
  • Open
    Votes: 0 0.0%
  • Open
    Votes: 0 0.0%
  • Total voters
Prototype
Hello, people, i Just Joined this Community tonigh 12/03/2013 at 7:40Pm
My problem:
I have a (1999 Stang, V8) (after 3 years with no problems)Stock heads where messed up by Cyl#3 .. I REPLACED heads for semi-new(1,200$ 1 year ago) Before putting heads back, Mechanic ADDED some special HELICOILS that where installed before final installation so that it will have more thread and it will avoid getting another spark plug blown. After installation (1 year later 10/12/2013 ) Cyl# 5 decided to break, I sent it to the shop for Helicoil job... :cautious:, Today 12/3/2013 Cyl#3 is misfiring, i turn the car on, and i can feel the low compression, i use my OBD2 machine and Cyl#3 is back again after so long..
My Questions:
Can i add STRONGER HEADS with STRONGER SPARK PLUG THREADS to my stang?
Can i add cobra heads to my 99 stang?
Where can i get an upgrade for this FORD HEADS Typical problem?
I live in CA Inland Empire Close to L.A...
Any advise or comment is welcome, negative feedback, just leave it for later.. THANKS in advance
:(i was looking into that, but would it work in a head that was already using a helicoil.. is it possible to reuse the same hole after being use with a helicoil...
I think 03-04 gt heads have more threads for the spark plugs. If it's not that bad I think you can fix it yourself, here are some basic how to and the tools to get it done. http://www.timesert.com/html/ford_sparkplug_faq.html
Are you sure it's a stripped spark plug hole? If you are gonna replace heads maybe it's tone to upgrade and get tfs heads or do a 4v swap.
03-04 PI heads are the same from 01-04. The 2005+ crown vic heads are what your looking for, thats when ford added more threads.
Really, the Windsor heads are the most notorious for this. I have several friends over the years that have had the same problem with theirs, two of them bought their cars with the problem and the PO was kind enough not to tell them they had been heilicoiled. I have never seen a Romeo have this issue (didn't know the 05's had updated threads, glad I read that).
+ 1 on using timesert
This is why I when I bought my 2000 I checked each plug before I bought it and so far so good. (knock on wood)
