Hits Keep Coming Part 2
88GT954
Hollywood FLA
During the removal of the dash I was disconnecting the plugs from the steering column and found major problems. I have no idea what to do now. Help please.
Recall on Ford Ignition switches:
Some of the symptoms of ignition switch problems are things that don’t work or are intermittent like radio, turn signals, wipers or heater.
There was a FREE recall on Ford ignition switches. They overheat and sometimes catch fire. That burns up the steering column and sometimes the car interior. Since this is very old information, you may not be able to get the switch replaced for free anymore. The auto parts stores sell the switches for $13-$15.
Saleen0679 was nice enough to dig this up for us awhile back: Replace a 1979-1993 Ignition Switch Assembly
Ignition switch wiring
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
didnt know about the recall?!...i will have to check mine out!....but thats why i asked why you were taking it apart,if you have no issues,consider yourself lucky and just change the connector....
Latemodelresto.com has all the parts to fix that stuff, inexpensive and free shipping no matter how small your order is. Don't do what some tutorials say and try to drill out the torx bits that hold the ignition switch to the steering column. Just spend a couple dollars at Advance or Auto Zone or anywhere else and get the proper bit. I believe it is a T-27 security bit, but double check that.
He's right.
For less than $10 you can get a full set of bits and a 1/4" hex to 1/4" square drive. It's a great addition to your Mustang tool kit..
