That appears to be what's left of your ignition switch, located on the bottom of the steering column. @jrichker for the install writeup
Bad heater core.little more info would probably help....why were you talking the dash apart?....was there and issue?
Latemodelresto.com has all the parts to fix that stuff, inexpensive and free shipping no matter how small your order is. Don't do what some tutorials say and try to drill out the torx bits that hold the ignition switch to the steering column. Just spend a couple dollars at Advance or Auto Zone or anywhere else and get the proper bit. I believe it is a T-27 security bit, but double check that.
