Build Questions
rodknockracer
Hey all, new to the forum. I got a 92 hatchback 5.0 I plan on driving to Mustang week. I want to do what's called a "ranger swap". The guy at the junkyard said that the package costs $500. I'm gonna weld some ranger twin I beams across the front from spindle to spindle. He said it reduces the wheel hop and the fox body lean. He said that I'm gonna need to throw the 3.0 engine in because of the weight reduction. I already bought it so I'm gonna paint it and put it in today. As far as interior goes I hope to use some ranger seats too. The guy said the seats he has for $750 are clean but his dog had an accident on them. Has anybody done the ranger swap? But thanks guys for the help hopefully I can get it built for myrtle Beach. Mustang week 2014 here I come !
i have never heard of that front suspension swap, and to tell you the truth it sounds like that guy has some ranger parts he wants to get rid of, and he also wants to experiment on your car. not to mention there really isnt much room for twin I beams under your fox body. and then there is the step backwards in performance with the 3.0l engine.
if you really want to cure some of the mustangs issues, then swap the front K member to one from a 94-95 stang complete with control arms and steering rack. that gives you a better camber curve due to the longer control arms, and five lug brakes that you can later upgrade to 13" cobra brakes if you wish.
at the rear grab the 8.8 from the same mustang, again five lug axles with disc brakes already installed. to eliminate wheel hop go with a torque arm suspension from some one like maximum motorsports.
you will need to get the right back spacing on your wheels to clear the fenders, but that isnt hard. in fact i believe that the 17s from a 98 mustang fit rigtht nicely , but check to be sure.
that set up will do more for you than some frankenstein cobbled together suspension will.
Alright thanks a lot guys. A little research and help can go a long ways. And so can a wrist pin from this torn up 3.0 the guy sold me. I put it in with a carb conversion and it busted a whole in the block and busted the wind shield with a nasty chunk of Ford. Back in with the 5.0 I guess. Also is there any way to get a lug nut off that is on a wheel stud that has come out ? I used my plasma cutter on it and cut a chunk of rim and rotor off. What a mess. Thanks guys
Wheel hop happens at the rear axle, how is welding in I-beam FRONT suspension going to help wheel hop in the rear!!!!?
:tard:
There's a sucker born every minute. Also, I-beam suspension is awesome, for trucks! Especially pre-runner offroad trucks. Not mustangs.
