In light of yesterday's JF that was the primer fiasco, I decided that that hood could sit awhile while I got my mind right about it.
I decided to "go with what I know" and do some Chop, cut, rebuilding of my own.
The plan was to fabricate the door bar for the drivers' side door. Before that could happen I needed to get my Fedora, my heavily worn, brown leather coat, and my bull whip out because I had an archaeological dig to go to.
These are the receiver lugs that are set in my driveway to allow me to bolt my tubing bender down. Since the instances that I use that bender are so infrequent, those four holes will fill up with dirt a,metal grindings/dust and literally dissappear. If you were my neighbor, and just happened to look out your kitchen window at the right moment today, you would've been able to watch me staring at the ground, looking for them. I'm sure you would've been convinced that I was just as crazy as my real neighbor does.
But, after a few minutes, I found them, and commenced to dig them out.
So I could park this thing there.
One of my favorite tools. And next to the Wagner airless paint system I also own,...probably used just about as often. ( Actually, I use the bender more,....I freakin hate to painting anything involved with the house)
The only thing I had to get started with was one 60" long straight piece of 1.250 DOM tubing that I had been keeping for just this purpose. The door bar consists of 7 bends, and all of them are really close. Invariably you have to make a bend, and cut and section the entire thing together. In other words, you can't make several bends continuous on the bar.
The first two bends down, and tacked
I can TIG, but I'm just..........."competent". Since I'm grinding down every weld smooth, I really wasn't gonna go through the ordeal and just use the MIG,...but I figured what the hell, I'm never gonna get any better at it if I keep passing on the opportunity to use the damn thing.
Not the prettiest TIG weld you'll ever see, but in retrospect, waaay easier to grind smooth that the MIG. In hindsight, I'm glad I hooked the thing up after all.
Each one of the bends are all exactly the same. You stick the bar in the bender, lock it in place, engage the first tooth of the spreader,........and pull.
This bender will make a 90 degree bend. Everytime you pull one full sweep, you back it off, and engage the next tooth. Once you run all the teeth out, you move the entire die set back and reset a pin that moves the die forward, and then start all over again. In the case of these door bars,... I only had to run the first course of teeth,.......makes about a 22.5 degree bend .
Then you take the bar out,...and cut it.
I'm sure that to a chassis shop, using a large tubing cutter to cut this stuff is nothing new. Hell, they may be using something even slicker for that matter. But this takes about 30 seconds to make a absolutely perfect cut through .085 wall mild steel tubing. Gone are the days of using a HF chop saw that throws metal sparks, and grinding junk all over the place. Besides,...if you ever had one of the cheap HF chop saws,.....chances are you have to beat on the handle to get it to start,....or it's in some landfill.
The tubing cutter never fails.
So the day progresses along that way,...make a bend, cut it. Tack it with the MIG, Weld it with the TIG. Grind it down,...Yell at the dog to shut the hell up, move on to the next bend.
Lather, Rinse, Repeat.
It gets to a point of almost being done, but you gotta make the mount legs that will hold the stupid thing on the door.
Out comes more HF junk.
HF Tubing notcher,....clamped into my HF drill vise, sitting on my HF drill press.
Once cut, notched, grinded to fit, and welded, you finally have the makings for a Driver side door bar for your 1978 Ford Gila Monster Fairmont.
The $64,000 dollar question then, is.... Do they match each other?
Close enough.....I'm so sick of having to make two of everything on this car I could puke. Everywhere you look there are two "fraternal twins" on the car,.....Not quite identical, but from the same mommy, and the same baby daddy.
It's just gonna have to do, pig.
So are we done then?
You aren't even close to done.
You still have to make a mount on the door. There is still the mounting flange, and cover trim that has to be cut, bent, welded, drilled, and tapped to hold the mesh grille that matches the dash. There is still an "arm rest pad" that has to be integrated into that door bar. Then hours of smoothing, filling, sanding, priming, and painting. before it can actually be put in place.
But at least it's farther along than it was this morning,........When it was just a straight, 60" long piece of .085 wall 1.250" diameter DOM tubing.
