This motor also gets 8psi from 1200 rpm up.I'd go with a Holley sm2 or eddy rpm2 over the long runner tfsr, the uppers work a little better (the box would beat any of em, but packaging is tough). BUT, even with a fully ported set of GT40's (especially with that cam and those flow numbers) any of those three would be overkill.
This new intake thing is mostly due to the car hitting a wall at 5300rpm or so even though I'm still in boost.
I'd blame that baby ecam (or even maybe springs, don't know which you have but even the common tfs springs are a bit weak) more for huge falloff like that, not that the cobra intake doesn't contribute to it, but I just think it'll be even more noticeable with the bigger intake if the cam is the limiting factor.This motor also gets 8psi from 1200 rpm up.
Pics of ugly set up?
Man.... tough crowd.
this works but must go. I have a thick sheet of aluminum I would like to make a plate with for the pulley mount, then do away with the bar coming off the SC plate.![]()
