FINALLY! Got to drive the car today.
After some minor tweaking of the cables adjusting of the brackets and general riggery, I drove my f'ing car!....
After the short trip I washed waxed cleaned and protected. Then laid the top back and got sideways for a long drive.
I actually pulled some timing out of it, with everyone's blown head gaskets and whatnot I played it safe. Now at 8 psi 24* timing.
After reading thru my datalogs, I realized my throttle never went past 83%..... wtf?
I tested it in the drive and sure enough my tb never opened up all the way, I really have to mash the gas hard... maybe I need to adjust the bracket some.
After some more tuning and another break down (powdercoat) I will be making an appointment at a local dyno shop so I can get some numbers on paper.
Soooo........
Let's play the guess my HP game!
If you've forgotten here is the parts list.
-306 balanced 3000miles on it so far.
-gt40 heads did my own porting 2.02 1.6 valves (valves backcut) with fully adjustable valve train
-e303 with 1.6rr
-cobra intake again home ported
-65mm and a 75mm tb.
-m90sc. With homemade sheet metal inlet outlet.
- 8psi 2k-3400 rpm, by 5800 tapers down to 5 psi.
Any guesses?
I bet peak torque is around 3k
