Sparky714
5 Year Member
Why are the wideband in however you would like I would suggest grounding it to the mega squirt ECU ground. Just take the White Band output to the O2 input on the board you can do this through the DB connector or solder it into the 02 wire on the stock harness it's really your choice. If the car is A5 speed car then I would suggest wiring the clutch into one of the extra relay inputs that would be POA or Flex there are others I will have to dig up the documentation for you for now just do the jumpers the way the documentation you have says we can go in once I find the other documentation and add the extra jumpers then we can grab wires that go out into the engine compartment and use them as outputs four relays this will ground the relay and then use the relay to turn on another device like electric fans or shift lights if you're planning on running supercharged in the future then everything that came in the kit is good for 20 pounds of boost good luck take your time
Oh, I see now, the 15pin connector can be configured for anything I want. I missed that. I'm going to make up a harness to bring out any future options I want to add.
I'll get it wired the way the documentation shows and start with that.
