Sn95 5.0 Engine Rebuild
Hot tanking is just a method of cleaning the block after it has been disassembled. It gets all of the old crap and looks, essentially like a newly made block. It is very effective, not as many shops perform this properly anymore because of EPA mandates with the chemicals used and disposal of the wastes after cleaning the block. Uncle Sugar wants his dime in other words.
Magnafluxing the block is a method of checking for problems in the integrity of the block (cracks).
The actual number is .010 on the block. This mainly means a hone will be run down each cylinder to restore the cross hatching the rings need to provide a seal and prevent blow by of oil to the combustion chamber or air fuel mixture into the oiling system. If you hear of a larger number like .030 (30 thousandths) or larger, it means at least a slight over bore of the cylinder. .010 would mean new rings, .030 and larger means new pistons usually. When the number is larger than your .010, it means it's being rebored. When you hear of a 347 or a 363 engine based on a 5.0. It means it's been rebored extensively and/or had the connecting rods changed for a longer stroke, which means a new crankshaft as well. All in effort of more cubic inches. Because there's no replacement for displacement (ok, a turbo or sc can be argued here, @Boosted92LX ?).
Cubic inches are hard to compete with.
Reactions: Davedacarpainter
5k is a fairly steep price for what your motor sounds like it needs. If it is just going to be reringed,crank+rods resized w/new bearings,etc that's a very steep price. We're talking about a few hundred in machine work and another few hundred in parts. Add in a new cam,lifters,timing chain,some head "massaging" you're really talking about 1500$. So his labor is going to cost 3+k? Ouch
:scratch: This made my head hurt:bang:.
If it is already costing 5K, walk away. you can buy a crate engine for that price and then some.
https://www.summitracing.com/parts/mll-bp3060ct/overview/make/ford
Put the intake and accessories on and your done.
I think the point most are missing here is the shop is not only removing the engine for you, but rebuilding, and reinstalling the engine.......which times that by a shop rate and parts......makes sense sort of.
Most people forget LMR sells GT40Ps for 600 dollars :crazy:
If you do not procure the parts yourself, a shop will charge out the a$$
Yup. That's the truth. A lot of guys here are the DIY type, so when they see $5K for what they could do in a few weekends, it's sure to get people worked up.
I don't really think the OP needs to worry about originality at this point. The motor is a rebuild, .010" over. It really doesn't matter. Slap some GT40 heads on it, an exploder intake and a aftermarket cam and have fun with it. All those parts can be removed if SN95 5.0's ever become collectable. Unfortunately, right now, they aren't. It's the 87-93 cars that are.
Unfortunately, adding different parts at this point might add cost to your total bill...which is pretty excessive at this point. You probably could have sold your car for parts, added $1K to your rebuild bill, and bought a modded Sn95 5.0 with the mods already installed.
might as well just do the stock rebuild save up for a 2013 5.0 engine and dump that in there ... BTW will the new 5.0 even fit in a SN95??
Yup. A lot of guys are doing this swap. Most use F150 5.0's as they are a lot easier to get a hold of.
However, you'll need a lot of supporting mods as well as the motor. new Kmember, engine harness, computer, convert brake system to hydroboost. Not a cheap swap if you are DIYing it, even more expensive if you have to sub it out to someone to do it for you.
A 2013 "coyote" 5.0 swap with supporting parts etc, 15K easy.
You should drop by the shop and ask him to show and educate you, if he's been doing it this long he shouldnt mind and you could play back what you learn with folks here for validation and clarification like youve been doing,
then you can figure out where to go from there ....
The guys are right, this is a good learning experience all around.
You have to admit, you already know more and must be a little bit less intimidated by your cars mechanics.
@89oem is right, if this guy has been in business this long, he really shouldn't mind you being inquisitive about your car.
It's not voodoo, it just takes a little studying and doing.
Reactions: Brian Berthold
HATE IT HATE IT HATE IT im gana burn this POS to the ground ... got car today drive it the 50 miles home .. have to drive it the 50 miles back cuz something isnt right!
this is list on what he replaced ... the crank isnt on there but it was replaced
and this was why the rebuild was so much just over 4K
what i dont get is i would call some of this stuff part of the engine rebuild ... like the harmonic and the coolant and spark plugs
Those are actually pretty fair prices from a shop and none of those items are in a rebuild kit. It's an itemized break down of everything purchased and he laid hands on. Those extraneous items never make it into the Summit or LMR ads offering stroker or rebuild kits, but damn if you can't get the engine back together without them.
What's puzzling me is why you needed a new starter? Was that bad to begin with?
it was warped or bent or whatever .. its what shot the engine to **** .. well it was the harmonic balancer really the damaged the crank
Ahhh.. that will do it. What's the car doing that you need to take it back? You're coming off a fresh rebuild, keep in mind there is a period of time for things to break and settle in.
the starter was covered in oil as the rear main sall was bad
whats it doing ... to me it has no power
at lights when i stopped for more then say 25 seconds
the car shakes like its missing .. the RPMs are going from 500 to 1500 with the shake
the RPM dont fallow the engine slowing down - it sticks at 1500 and then drops down once stopped
and the engine wont push it into passing gear
all these thing it did not go even with a messed up engine
Pull codes. In all likelihood there is a bad connection somewhere or perhaps a vacuum leak. If it was stumbling that badly he shouldn't have released the car back to you.
Take video of the car not performing. Your mechanic needs to see that to correct the issue.
i dont know anyone that can pull codes everyone says that can only read OBD2 .. and mine is a OBD1 ... but there is a ford deal across the street from this guy
