Steve's Megasquirt/tunerstudio Help Thread
hey Steve, finally got around to messing with my car some more I turned the screw on the throttle body down more and it started surging (I kinda expected that but it now sees 800-850 now) so the next time I cold started it I let autotune work on the WUE. Anyway here's a log if you wish to look at it.)
Also I emailed DIYAutotune about the going rich when the fan comes on and he suggested I ground the ECU to the same ground as everything else which I did (cant believe I forgot about the main ground) an. d he was concerned with my alternator spiking to 15 volts at times. I intend to get a new voltage regulator asap but have yet to do that.
  • 2016-09-04_13.29.54.msl
  • CurrentTune.msq
@Boosted92LX
Hey Allen was just wondering if you got the tune to work. If not I can go through the tune again and make the necessary changes for you and post a fresh copy of it right here
Thanks bud. I've been in bed with a bad cold the last 24 hrs and haven't made those VE adjustments you recommended. All I've done is sleep, eat a little and check stangnet when I wake up. When I get back among the living I'll let you know.:)
I know nothing about efi tuning, so I'm asking here for some advice, and to get some answers that will help me understand the basics of operation. I'm very knowledgeable when it comes to carburetors and engine building, but I'm not tech savvy, but I can learn!
I'm on the fence about getting the mspnp2 or PiMP. I've looked at all the other plug and play stand alone systems out there, and everything is pointing me towards the mspnp2. I'm ready to pull the trigger, but I'm still hesitant.
Remember, I know nothing, nada, zero, so please bear with me. I understand the basic install procedure... Yank the stock A9L ECU, install the mspnp2 in it's place, and run the vacuum line from the nipple to the intake manifold. Ok. Now, get the timing light out, connect laptop and launch tuner studio, start the car, make sure timing is set and matching in tunerstudio. Ok, now what?
I understand there is a base tune for my car ('91 Mustang 5.0), is this preloaded, or something I have to setup? Will this base tune basically act like the stock A9L ECU, and run the engine as such, just like nothing ever changed?
I see something about the auto tune feature, is this something I can run to get a simple tune setup that will work with my current modifications to get me in the ball park?
Please, explain as if you're talking to your grandma. I'll get it all eventually, but literally knowing nothing about this stuff, and not having any friends that know about it makes it difficult to comprehend.
Thanks in advance...
So what size crank trigger wheel are you EDIS guys using ? 6 3/4 ? And what are you doing for a bracket to mount a sensor ?
Looking to do this with my fast so I can take advantage of the sequential vs being stuck bank to bank .
Granted this setup is on the Monster, but the Balancer is 5.0. The trigger wheel is the smaller size, mounted (custom drilled) to the back side so that it wont interfere w/ the other pulleys on the front. The VR sensor is generic (probably) from some 4.6 Ford application.
Thanks bud
@a91what
Steve, I just wanted to drop a line to update you. I changed that VE table which made the car MUCH more responsive. It still had a stumble when coming into boost, so I opened up autotune and went cruising. After five miles or so, ALL of the problems I was having before had vanished! No more backfires when shifting, no dying coasting up to stop signs.. Very pleased. However, stupid here pulled into a gas station to refuel and shut the key off before saving the autotune corrections. Then, momentarily after in typical fashion for this car, a heater hose erupted into a geyser under the hood. I had to trim it shorter and limp home, but after it cools off and I straighten that out, I'm going to get back after it. I wanted to say thank you so much for your help man! It means a lot, if I can ever do anything to return the favor, don't hesitate to ask!
Reactions: 3 users
Glad to hear that it worked out well for you. Keep me posted on the progress and grab a datalog for review.
Good grief. it went from doing well to crap again. Overheating really bad. amidst the chaos I realized that I apparently Effed something up and an old msq file title was showing that it had been loaded, and I'm not sure wtf happened for it to get there. I did have a really hard time loading the revision you sent me, I kept getting an error. after saving it in several locations and attempting to load it from different locations, I finally got it to load..Now I'm going to have to figure out what's going on..:bang:
I gotta get better at this.
Hi Steve,
Tried the tune again this morning and got a log and a video for review. Still has bad oscillating issues, I'm really at a loss. I attached the tune I'm using, the most recent log and a video link here. It oscillates at cold idle then it's okay when warm, then the fan comes ON @ 185* and then it starts oscillating till the fan turns OFF. Sometimes I press the gas a little and the RPM is pretty responsive, but then the car dips below and starts oscillating until it smooths out.
  • 2016-09-14_13.55.11.msl
  • 94CobraTune2.1.msq
I have a quick question about the MAT air density correction table. My table is the one pictured if I'm reading this correctly would that mean at 194 degree temps it's adding 10% more fuel?
Sent from my iPhone using Tapatalk
Yes, although I'm not sure why you would change the table at all... The base table works off the laws of physics lol... messing with it affects the fueling drastically. the base table ensures that the temp doesn't affect the AFR and the same rpm*kpa value delivers the same fuel no matter the mat temp. just a FWIW...
for temp fail safe I just pull butt loads of timing.
I had the car Dyno tuned so I didn't make those changes and yes the runner did it as a fail safe since the car is boosted but the problem I have it I regularly see intake temps above 190 so everytime I'm in boost my afr drops to around 10.4
Hi Steve,
does the car still hunt around with the CL idle turned off? you should be able to easily idle below 1k without a hunt. Try the idle set to " warm up" set the table to all 50% and see what happens, also turn off the idle advance control.
Simple way to fix it. Post your tune up and I will look it over, if you like I will upload a base mat correction table to the tune. then I will set up the mat temp retard table fairly aggressive so that it pulls enough timing to affect the AFR. I am boosted as well this is how I do it.
You just need to save your current tune use the "save as" and give it a name like...'Dyno tune' then save the one I give you under something else so you can tell them apart. when you go to upload the one I adjust it will show you a difference report.
for instance at 194* you have 30% more fuel than you should..... just sayin.
1) Remember, I know nothing, nada, zero, so please bear with me. I understand the basic install procedure... Yank the stock A9L ECU, install the mspnp2 in it's place, and run the vacuum line from the nipple to the intake manifold. Ok. Now, get the timing light out, connect laptop and launch tuner studio, start the car, make sure timing is set and matching in tunerstudio. Ok, now what?
2) I understand there is a base tune for my car ('91 Mustang 5.0), is this preloaded, or something I have to setup? Will this base tune basically act like the stock A9L ECU, and run the engine as such, just like nothing ever changed?
3) I see something about the auto tune feature, is this something I can run to get a simple tune setup that will work with my current modifications to get me in the ball park?
4) Please, explain as if you're talking to your grandma. I'll get it all eventually, but literally knowing nothing about this stuff, and not having any friends that know about it makes it difficult to comprehend.
I've numbered your questions so it's easier for me to answer them. So there is no confusion, I'm a Stinger PiMPx/PiMPxs tech so the answers will be for that ECU, not the pnp2, though some of it will apply to both.
1) We provide a 20 page startup guide that outlines every single step from removing the stock ECU to firing the engine for the first time. It's go pictures, diagrams, and of course the actual text that outlines when to do every step of the way. If you follow these directions exactly as written, and don't do anything it doesn't say to do, you don't need to know anything about EFI, tuning, MS products, etc to be successful. Our typical customer has no EFI tuning experience prior to buying our ECU.
2) Our base tune comes from a real car with similar mods to yours. With that said, it doesn't come pre-loaded because there are some steps in the setup process that require you to crank the engine before it's capable of starting so we pre-load a tune that won't fire the injectors to prevent you from pushing a bunch of fuel into your oil during this process. With that said, loading the base tune takes about 5 seconds and how to do so is outlined in the startup guide. The base tune isn't set up like an A9L because it 1) is based on your mods so only a stock 5.0 would want an "a9l" like tune, and 2) the ECU's share no components, use different strategies (MAF vs Speed Density), and therefore there is no real way to make one just like an a9l. As far as things being set up for you, for the most part yes. All of the "technical" stuff is pre-set and you'll never touch it. The warmup/startup tables are populated, fuel and spark tables are set to as close to your mods as we can do without having datalogs from your vehicle, etc. There are some things you have to input because they aren't saved in the tune but rather are saved in the ECU so they don't get reset when you load a new tune (coolant/air temp calibrations, TPS calibration, wideband o2 calibration) and also the required fuel value (engine size, injector size, fuel type). We "could" set the required fuel value for you but it's a very simple thing for you to do, we say where/how to do it, and we have a good reason to have you fill it out that is explained in the guide. The intended end result is for your engine to start/run on the base tune. It is not intended to not need any additional tuning is this isn't really possible with any ECU. Nobody can nail a perfect tune out of the box with no feedback.
3) You can use it. It doesn't get you in the ballpark, it gets you exactly where you (or the base tune) tells it to be. This is a VERY powerful tool that works very well when it's getting accurate info from the sensors (bad info into the ECU = bad tune coming out). It is as good or better (and certainly faster) than a "human" tuner 95% of the time. Keep in mind though that it only tunes the fuel, it doesn't tune timing (this needs to be done on a dyno, if you feel you can do better than the timing table we provide).
4) I tried, hope I was helpful. Our startup guide does go through multiple changes as we get feedback from customers so we try to make it as "easy" as possible to understand. If something doesn't understand something and we explain it to them in a different way and they get it, we edit the startup guide with this new wording in hopes of others not having the same issue. This way it's as "easy" as possible to understand. Also keep in mind that for the PiMPx/PiMPxs, it's MS3 based which is the newest MS version, not MS2 based like the other PNP options so it's got a lot more bells and whistles. It also comes with all options "built in" so there is no need to send it back for upgrading. It's all baked into the base price. We also have a dedicated support forum just for our ECU's that focuses entirely on Ford engines of this era and all of our ECU's are identical so there is no worry about finding info that doesn't apply to you. The forum has paid tech individuals who check it about 20 hours a day and are ready to answer any questions that may arise, or help you tune your setup, or answer questions about settings or steps you don't fully understand.
