Water Pump Went Out And Now Motor Makes Noise
Also looks like a small leak coolant leak behind the timing cover gasket, and a small leak from the drivers side steering rack. So add a few more thing to the list for the spring. The steering rack seems pretty easy. And we will do the timing cover gasket also. But that is for another day!
Here is at leats a pic of the money pit! haha
Reactions: A5literMan
Looks like a clean fox, make sure you soak the bolts (timing cover and water pump) the night before with pb blaster and label them.
Also with budget minded enthusiast, and broke kid maintenance (bare with me a second).
Sign up for advance auto speed perks and use the code TRT41 when shopping online.
Why online?
You can order your parts online and pick up to your local stores within 30 minutes and that code will give a $40 off a $100 purchase. I abuse the crap out of that code for (parts, rtv, pb blaster, and brake cleaner). Keep the cheddar in your wallet my friend ;)
this car sounds all sorts of abused. pro tip- find a mountaineer or explorer in the JY. cost to pull should be under 500. comes with the better intake and heads. swap over the fox oil pan, cam, front accessories, and flywheel. congratulations. you now have a 93-95 cobra spec engine for under a grand.
Kid already picked out a top end kit for about 3 grand. A trick flow kit from late model restoration
While that is a good kit, you still will need to replace the water pump,balancer,and while at it...all gaskets,oil pump and pickup. You also will need a new bigger fuel pump and injectors,MAF,and throttle body. All said plan on 4K on parts and another 1-2k in labor(if not doing it yourself).
Reactions: mikestang63
Sure hope you got the car for a good price. I hate deceitful sellers. My favorite color though! Good looking blue. Put a wanted engine on our classified site. One of the forum members may have a nice motor , fair price for you.
Sent from my iPhone using Tapatalk
You know, all advice on what engine to build aside, I shudder at the thought of my 16 year old driving a 300hp+ fox. That's not a lot of HP by todays standards, but it's mostly all available under 4k rpms which is a blip of the throttle and these cars have all the safety features of a candy wrapper.
Yea we wouldn't let him get it as his first car, He is almost 18 and is a pretty good driver. In fact he drives for the company i work doing deliveries in the summer months. But it appears he has a found a motor, that will need to use his intake, distrubuter and pulleys.
