- Jan 21, 2017
- 51
- 0
- 6
Gonna get codes today and let y'all know not going carb got to much in the harness it's a complete racing harness to o2 sensors to computer i have no salt and pepper shakers either
Sometimes runs fine than all of a sudden you feel it like there's a trailer on the back and then starts popping and losing power slowing down I have a gauge on my fuel rail and answering about 30 want to bump it jumped down to about 24Just for curiosity sake: Does your car run fine and then while driving the car loads up and starts popping and potentially backfiring? Then randomly clears out and does it again intermittently?
Is the car a stick or auto?
Also are your O2 sensor 3pin or 4pin?
Ya just went double checked it again when I bump the throttle it might hit 31 than drops to 26 thank climbs back to 30lbsI want to say mine sits at 30 and jumps to 39 when i give it load
I think 3 pinJust for curiosity sake: Does your car run fine and then while driving the car loads up and starts popping and potentially backfiring? Then randomly clears out and does it again intermittently?
New fuel pump, crap forgot about thatDid you change the fuel pump and filter?
Ya is adjustable it sets at 32 and 39 unpluggedYou forgot to crap? Not good!
Now seriously, check your fuel pressure, should be 30+ lbs at idle with vacuum and 42 ish with vacume line unplugged.
I think you said you replaced fuel pressure regulator, is it adjustable?
