Ok fellahs Ive looked through old posts and cant find an answer besides maybe mass air meter, my car is a little different than the regular 94GT. I have a Factory Five Cobra with the 1994GT running gear including ECU. The engine has TFS top end kit with B-303 cam, BBK 75mm TB, Granatelli mass air with 24lb injectors, also a MSD 6A ignition. Couple a weeks ago I installed a Vortech base kit to start with, the car runs pig rich and surges at idle but off idle it drives descent just rich.
I removed the blower belt and the car cleans its act up and idles, also a little leaner, its as if it were the same as before blower install. I put the belt back on and same old thing rich and Smokey. The Mass air meter is in front of the blower and then the IAT sensor is right behind it then the blower to TB.
The previous owner of the engine and harness has a mass air modifier installed, I cranked the idle knob all the way to the bottom and its a little better but still rich and surging but not as bad. Makes me think TB and its readings have to do with problem. Any suggestions anyone? Is it something a tune can fix?
