The piston guy was right.
I would see the problem with my naked eye. And I know now how to fix it.
I have to stop smoking crack.
With the #5 top ring pushed 1" down in the bore and squared up, measures............031"
It's supposed to be .025.
And that is only
IF I go over 15 psi.
IF I keep this engine under 15 psi...
It's supposed to be .020.
It's also supposed to have a nice, square end surface that meets the other end surface...
Mine is all wonky, and un square.
I know what happened. It's simple. I messed up.
Clearly, the ring gapping process requires a very dedicated work ethic, and the right equipment to do it.
I thought I had the right equipment by buying one of those hand cranked ring filing wheels. I am certainly capable of doing tedious work...I built the entire ECU from a kit as a testimonial to that.
If only I hadn't smoked that crack pipe..
![NoNoNo :nonono: :nonono:](/smilies/nonono.gif)
..What was I thinking?
The good thing is that the same ring set is only 85.00 bucks for a six ring set, or 132.00 for a V8 set ( which leaves two complete sets should I not be able to resist the Siren call of the Crack pipe mistress.)
The six cylinder set isn't in stock, (I'd have to wait till the first week in January to get it.) the 8 cylinder set is. ( Go figure,....you 8 hole boys always get your cookies, ANND your milk at the same time)
I want to order a taper style ring compressor too,...getting the 6 cyl set leaves room in the budget to get that...
It's not like I'm going anywhere anyways, and there is a lot of reconfiguring to the existing stuff that I wanna do as well....Screw it,..I'm ordering the 6 banger set, and the ring compressor.
