Progress Thread Project: Buried Under A Mountain Of Snow Black Hole Money Pit.
this is also fixed...but i will be drilling out the rivets and bolting them in.
also picked this up....
Reactions: 3 users
@TOOLOW91 how much wire did you use to do your holley system? i just ordered 1000 feet of wire and i hope its enough LOL
Not much at all I used the pre made harness already and just had to run some extra for the fuel pump and stuff .
Now I have to look into adding some more cuz the fans and t brake are getting tied in
damn cheater LOL... i wish i could buy a pre-made harness for this
word on the streets are there is a 60lb box in route to my house from some where in ohio... wonder what it is:thinking:
these damn things worth anything or is it pretty much going to be taking up space in the garage?
:burnout:dropping it off tomorrow along with the oil pump and oil pump shaft.
the material for the steering shaft showed up yesterday also. now i just need the u joints. guess i need to call UPR and get the bump steer kit ordered and get the rack ordered also.
You say that your building a race car right??? If so, spray the he** out of it. If anyone can build something the right way it would be you.
honestly it will prob be less than a 250 shot on it... should make somewhere between 750-800 NA and the block is iffy after 1000hp. granted these arent set in stone numbers some guys get away with more some less. but we have a good plan on how to keep it together with the light weight piston and rod combo along with the shortish stroke. we are doing a half fill to try and help keep the harmonics down
