Yes..I thought it was because I was tired, and lost my patience...But,....
It's because placing the ITB's on the transition elbows is a giant PITA. All 6 of them have to be placed on the manifold at the same time, because you cannot get the shaft through each throttle body if they're bolted on individually. It hits the radiator saddle. Trying to put the shaft through the throttle bodies while each one has RTV slathered on their bases, then moving the whole wonky contraption over to the manifold, and trying to set each one on the studs is just a big giant hassle.
The bigger issue is the interference. The TPS sensor is all over throttle cable, The bulkhead where all of the wiring exits is there, the fuel fitting is there,..... it's just a giant jug fck.
Lastly,....even after all of that is dealt with.. there's the "will it run right?", and what am I gonna have to do to get it there. There are 6 throttle screws..No common vacuum plenum, leaves me wondering if it'll run speed density, or whether it'll have to be converted to Alpha N...
And I know so little about Speed density as it is...Alpha N is like a carburetor only with separate injectors...
What does the finger say?
Rememeber what I said I wanted.....Why I got rid of the Turbo in the first place...
I want it reliable....
I want it easy...
I want it to be done.
LS swap.......
Just kidding.
As for the welder, I just ordered the same one, I was not sure if it was the one you had or not. Amazon had it on a 6 hour sale the other night for $340!
Joe
I'll make it work on Franky
....a bunch of time and money spent going in a different direction.
