Which throttle body kit?
BAD91LX
1,186
9
48
Hurricane, Utah
So the new 91LX needs a new throttle body and EGR spacer. Figured it out today what was causing the loss of power and the smell. Looking at keeping it stock for now until I rebuild. What set up has everyone tried with the best results? Thinking of going 70mm. Car is an AOD.
If you have to buy aftermarket as we sometimes do, buy once and be done with it. Accufab 70mm...Good from stock to as much power as I've ever made. That said, I have a BBK 70mm this time because of finances and it's been just fine.
Reactions: General karthief
With that car being stock and all I would replace it with stock stuff.
What smell you talking about?
It has like an aerosol smell. There is a lot of grease and grime coming out of the TB and EGR spacer. I ordered a kit to replace them from LMR. Went with a SVE 70mm. I read that 65 and 70 would be great for stock and 75 for minor upgrades and 80 for forced induction.
I’ve made 740rwhp with a 70 ..... if the intake size opening isn’t the same size as the throttle body bigger isn’t always better.
Reactions: JD1964
Unless you upgrade the intake, a bigger than stock TB is not gonna help. The opening in the stock HO intake is smaller than 70mm. Stock GT40 intake opening is 68mm. And I think the stock HO intake is even smaller.
While TOOLOW91's example beats me easy, I make 400hp at the rear wheel with a stock explorer TB which is 65mm.
Reactions: TOOLOW91
Forced induction reduces the need to increase the cross sectional area of any part of the intake assembly; that's the point of it.
Kurt
Still went with the 70mm Now looking at buying the intake. Never seen this before so not quite sure why it looks like this.
Looks to me like that's buildup from the EGR cooler plate gasket leaking coolant, which could also be leaking into the intake and engine. Have you noticed any coolant loss?
Likely fuel pump.
that buildup looks to me like electrolysis, if it's kinda powdery, it's a condition when liquid flows through aluminum with steel parts like bolts or in this case studs. Gasket is definitely leaking. A new egr spacer and throttle body with new studs/nuts and washers are in order.
No I haven't. Car ran fine all the way back from California and never overheated even in the 109 temp. Just have power loss when I first step on the gas so no giddy up on it.
I wouldn't expect there to be significant coolant loss if that leak is just on the outside. Probably just seeping through and causing the buildup you are seeing. I agree with @General karthief , you def. need to fix that issue but that shouldn't be causing your loss of power.
