if we dont turn 10000 rpm at a minimum the earth will come to an end Mike....... you cant let that happen... can you... can you hear the people screaming....
custom cams cams cams ......
Seems reasonable to me!
Oh sure, ignore the custom made cam suggestions and point out the easy bolt on suggestion..Leave the man be.
It's Mike's car and money.Oh sure, ignore the custom made cam suggestions and point out the easy bolt on suggestion..
Don’t believe I stated otherwiseIt's Mike's car and money.
So.... Second Turbo?
Leave the man be.
I understand the 'not wanting to spend the 2k' on custom cams and what ever else is needed to be able to twist it up to the stratosphere, now he reveals a 'funny' piston ring.
He is in the throws of a full blown auto munchausen episode.
Bolstered by the 'one eyed' trans adapter, could mike be building this so it does fail and he can 'fix' it again?
Or is really looking for new ways to unintentionally torture that cat?
They don’t need them . Guys pull the stock twins for single turbo deals everyday . Simple and just as effectiveSo.... Second Turbo?
Who knew jumping in on bustin’ Mikes balls would be such a trigger.They don’t need them . Guys pull the stock twins for single turbo deals everyday . Simple and just as effective
Now you listen here! I ain't defending you, I'm picking on @RaggedGT !Firstly, I get that I’m being kidded, and if anybody deserves to be kidded it’s me.
Secondly, I don’t need anybody to defend me regardless of whether or not I need defending. In this case, the only thing missing from the last exchange above was my omission of some smiley face to convey my true feeling.
Ill add that now.![]()
This thing:
This is a 20v 1/2” drill purchased from HF. They now have 3 different “ tiers” of product in their cordless lineup.
This sweetie cost me 69.00...( said something about “ Compare to Milwaukee “). The guy at the counter wanted to know if I wanted to spend another 20.00 to give the thing a 2 year replacement warranty. ( (I chose not to). When I got home and opened the thing, and chucked up a bit, you can tell by the way that the thing tightened that it would be a problem sooner than later. Nonetheless, I started using it.
It drilled 3 holes and died. I had to dig through the trash can for the receipt.
The only thing that can be compared to Milwaukee with this flaming pile of Doo...is the color....other than that...Milwaukee it ain’t.
What are you guys doing to your tools?I'm surprised...I was hoping their Bauer line was better. I can't complaint though. The only thing I have purchased from HF that hasn't lasted is the $9.99 heat gun. I've gone thru 2 of them doing the wiring on my 85. The first one was kind of cool...it kept working but started to sound like a pulse jet until fire and smoke belched out. The 2nd one last about half as long as the first and just wouldn't turn on one day. The last one I bought is different style and I haven't used it much yet.
Question is, did you swap it out or get a refund and go by a Makita or Dewalt?
