Yessir or the relay will turn on when you turn the key off.
Your confusing me..If the key is off,..what difference does it make to anything downstream in the system?
ing rat's nest.
ing rat's nest to minor jumble of random wiring. It's probably better than my
ing rat's nest of wiring I hid in the fender.
for the stupid things I do (or am not doing) to my car, I know that he at least respects the hobby. I also somewhat share his sentiment of doing something different. To me the 20 year old kid that says, Yeah I got a car build. See my 2016 Mustang. I put a cold air kit and a bunch of chrome under the hood.
Whether or not removing the R7 “clt” resistor has any impact on gaining a cam signal, it damn sure has affected my sensor reading. I’d just put the thing back in place, had I not snapped it in half trying to pry it off the board.(Where are the freakin radio shacks when you need them?)
I needed them last year when I wanted to build my own variable-resistance box for testing airbag circuits in cars... Finding the pieces I needed online was harder than just walking into the 'Shack and going to the cabinet I needed and getting it. I miss Radio Shack, still have one of their soldering irons in the toolbox at work, and one of their CB radios waiting on me to install it in the 4Runner for use when on trails. TheirWhere are the freakin radio shacks when you need them?
just works (worked?).I give a fck, Mike, but then again, who the fck am I?It’s Saturday afternoon, time for another installment of the “ who gives a fck daily news”.
I’m glad to hear it man . My fingers are so crossed for you . This should be bad ass .I’m always better after a conversation with Steve....
My injectors click. It was all about going to the right place to test them.
Now,...it’s all down to one,......lousy,....25 cent resistor.
ill still have to put the interior back together, bleed the brakes, and put the front tires back on, and attempt to get them both pointing the same direction ( remember, there is a new manual rack there).
Which brings about the tally of the tape. What got changed since October, when I discovered the OG monster engine had died.
The 2jz.The engine got:
New redneck valve job.
Mad mike fabrications custom oil pan and pick up, new Toyota oil pump.Block was decked, and machine honed; New bearings, new rings, new head studs, rod bolts, and main bolts. The VVTI gear was opened, and resealed. The recip assy was balanced. New timing belt, New harmonic balancer. The redneck valve job forced me to re-shim every single valve, which are now all at factory minimum spec. The engine was converted to COP, and has new D585 ( truck) coils.New 95lb/hr injectors.
New intake, New 90mm throttle body, intake converted over to accept ford IAC valve. New exhaust header, new hotside.
The engine required new custom mounts to make it fit.
The turbo:
The same 68mm turbo I had last time remains. This time the car got converted back to the same style A2W intercooler I had in the previous build. ( but had to repurchase) All new cold side. New water reservoir, new heat exchanger using two horizontally fixed radiators, repurposed electric water pump for moving the water front to back. New 60mm waste gate w/ 15# spring. The water meth injection remains.
The trans:
Whew. I spun my wheels for a month before I had a workable solution for adapting the 4r70 to fit the engine. The final solution involved having my old converter modified to fit a 2jz flexplate ( it was also one of the compelling reasons for the engine rebalance).The a340 Toyota trans has a removable bellhousing that I mated to the 4 r70 after cutting the case back to the front pump face so that I could do that, and fabricating a bolted together “coupler“ to mate the two together. I put a new front pump bushing, and seal, and a tail shaft bushing and seal. I had to make a new trans mount.
The trunk:
The trunk got a new 15 fuel cell. That required a the trunk floor be cut away, and a new frame be built to hold the cell, and the reservoir/ pump and radiators that make up the water recirculating system. The fuel cell was modified to allow me to install a drop in 340 lph pump, my tube style fuel level sender, and to stuff it full of cell foam.
The Steering:
I adapted a 2009 Prius EPS steering system to fit the car. That also required I convert the power steering over to manual. I purchased a standard ratio manual rack, and tied the two pieces together with a custom made steering shaft.
And finally,..The rewire.
Everything in the new engine required that I bring the engine into the 21st century. I needed Sequential fuel injection, Variable valve timing, COP ignition, and a PWM idle valve to control it. None of that was there. And that required that I add those circuits.
All of that brings me up to tonight. This revision was a several hundred hour modification. This last month alone since being furloughed, I’ve spent close to 200 hours trying to get it done...200 hours.....Based on my pre-furloughed schedule of 8-10 hours a week relegated to working on this thing, it would’ve been the end of August to get to where I am this evening.
Woot! Woot!![]()
Ms let's you scale it to whatever as well. The resistor he removed is the bias resistor, basically it's the voltage pullup for the thermistor circuit.I’m glad to hear it man . My fingers are so crossed for you . This should be bad ass .
that’s weird it won’t just let you re scale the sensor . Holley will let you scale it and it’s done .
Circuit no workie without it.
Ahhhh makes sense !Ms let's you scale it to whatever as well. The resistor he removed is the bias resistor, basically it's the voltage pullup for the thermistor circuit.
He swapped to a manual setup so JayZ would fitWhat did you change on the brakes to have to bleed them?
Ah, I didn’t see that in the summary.
So, I guess it was a good idea that I added the one page summary of the past 6 months for those “ few individuals“...?
I forgot to include it,...or subliminally it must’ve seemed like a backwards move to me, and my brain blocked it from my memory.
