3g Alternator pulleys
TOOLOW91
Dirt-Old 20+Year Member
8,409
234
S.I.NY
Do any of you know where or know of a 3g 6 rib alternator pulley that is 2.75 inches . I know a 94-95 is 2 1/8 . 96-98 v6 is 2.5 inches . I’m looking for something that is 2.75 .
I am looking to put my custom asp 8 inch blower pulley with my 6 inch acc drive to get my water pump moving more water at idle . It will be slightly over spun from a 93 cobra After doing all the math . Where as right now it’s spinning slower then a stock 5.0 car or a 93 cobra car with the 93 water pump pulley and a 4.6 under driven acc drive blower pulley at idle .
The alternator must be addressed as well because at 7200rpm if I didn’t change the pulley it will be on fire at close to 20k rpm with the current 94-95 pulley . If i go to the 2.5inch alternator pulley it’s still a little higher then I’d like at 17,280 . For the split seconds it would live there I don’t think it will hurt it but I’d rather be down around 15k rpm at max rpm .
So that leaves the question of does anyone know if one exists ?
In case anyone was curious . They say are 16k is the limit for failure on the alternator .
Water pump and alternator speeds
4.75inch stock w/p
4 inches 93 cobra
5.2 inch crank pulley cobra
4.6 diameter on Vortech ( 8 inch blower)
4.75 diameter on Vortech (6.87 blower )
6 inch stock mustang
1000 rpm idle Speed
Water pump Speed
Stock 1263 rpm
Cobra 1300 rpm
4.6inch crank 1150 rpm / 6.0 crank 1470rpm
4.75 crank - 1163rpm
5800 rpm
Water pump speed
Stock 7326
Cobra 7540
4.6 inch crank 6669/ 6.0 crank -8700
4.75 - 6887
7000rpm
Water pump speed
Stock 8842 Rpm
Cobra 9100 rpm
4.6 drive -8049 Rpm / 6 inch drive 10,500 rpm
4.75 drive - 8312 rpm
Alternator Speeds
My car 2 1/8 Pulley ( stock 94-95 3g)
2.5 - 96-98 v6 3g alternator pulley
4.6 Crank at 6800 rpm = 14,685 rpm
6.0 Crank at 6800 rpm = 19,154 rpm
4.6 Crank at 980 rpm= 2,116 rpm
6.0 Crank at 980rpm =2,760 rpm
2.5 alt pulley -
4.6 Crank / 6800 rpm = 12411 rpm
6.0 Crank /6800 rpm =16,320 rpm
4.6 crank / idle 980rpm = 1803 rpm
6.0crank / idle 980rpm = 2352 rpm
2.75 alt pulley
4.6 crank /6800 rpm =11,374 rpm
6.0 crank /6800 rpm =14,836 rpm
4.6 crank / idle980rpm =1,683 rpm
6.0 crank / idle 980 rpm =2,138 rpm
I know from reading all the various cobra forums that alt rpm is a major concern for those that change lower pulley sizes. The go to company for most is Metco. However, those are for 8 rib belts. Maybe give them a call and see if they’re willing to machine a 6 rib in the size you’re after.
Thank you ! Didn’t even think of metco
Standard 3G pulley is 2.4" (60mm).
Overdrive pulley is 1.75" (44mm).
ASP520004 from Auto Specialties.
I’m not looking to go smaller . I need it to be larger . With a 6 inch crank pulley even at 2.5 it’s still spinning faster then I’d like .
I posted the calculations . For what it’s worth it’s 2.5 inches at th top of my calipers on a 3g pulley for a 96-98 v6 car . P/n - GP685
A 94-95 gt is 2 1/8 (2.13 on the calipers ) p/n -gp712
A lot of mis info out there on the size of these pulleys .What I’m giving you I have physically checked and measured myself . I even burned one up at 20k rpm the first time tried the 6 inch crank pulley I had made ( 8 inch blower ) . Which is what led me to look into what happened realizing I never accounted for the smaller alt pulley at the time .
At that time I had switchwd from a 4.75 crank drive pulley ( 6.87 blower ) to the custom asp I had made . Now I’m going back to the 6.0acc pulley to speed the water pump up but I need to take the alternator into account.
Here is the picture . These are both motorcraft pulleys
I spoke to ASP today . He said he can make me one .
125 in steel and i can have it in 2 weeks
100 in alum and i can have it 4 weeks
If any blower guys ever run into issues and try different things I hope the pulley sizes and rpm stuff helps .
Reactions: 1 users
Just curious, how often and how long are you running at 7000+ rpm?
I looked on rockauto.com and found that the 1998 Ford Contour V6 has a pulley about what you are looking for. I looked under re-manufactured alternators and the ACDELCO ones listed pulley size. Re-man'd had a 2.7" pulley. Under the new alternators, the ACDELCO unit listed a 2.8" pulley. Might be a place to start.
Link to re-man'd
Link to new
  • Loved It!
Link to re-man'd
Link to new
When the car is finally tuned again and I am out messing around it will see 68-7200 . My concern is not having anything else to worry about more then I already do . I’m sure 1-2 trips there is fine but even if it sees high 16k rpm at 6800 that’s an issue . It’s going to give up at some point . I have experienced it before . When it had the manual still no lift shifting it would go to 7400 sometimes .
Link to re-man'd
Link to new
Looks like it may work . We’ll see . It’s no longer made . The part number is FOCZ-10344-C or GP-683 on the pulley itself
I got one coming from eBay for 35$.
I feel like there is a good Excel spreadsheet pulley RPM calculator that never got made that would come in handy here.
but then again how many guys actually calculate out pulley RPM? Not many I bet
I don’t know if anyone has dug this far Into seeing how far off pulleys spin from the oem designed rpm with different crank pulleys like I am so I have to agree . The lack of info out there is sort of what pushed me to do this and a make a small chart . Not that it’s ground breaking but hey it’s here .
Reactions: 1 users
hmmm I should look into this as well. I'm running a custom crank pulley 6.81" I believe and a stock alternator pulley (8 rib) off a 99 navigator. Never dawned on me that i may be over driving the alt too much. will they give a deal on 2 pulleys if they have to make them?
I just tried ordering the contour one Off eBay
to see what happens , it’s worth checking yours to make sure it isn’t over spinning at your shift point .
So what are good targets for idle and max rpms on the alternator?
And a spreadsheet should be easy to make, my brain is just sprained at the moment.
depends on the alternator. They vary. For your common 3G I think max is 18000 rpm but I forget what full charge RPM is.
I know I could get away with the 16k it will make with the 2.5 pulley but if I can be around 14k and 2100 at idle I like that idea better then being on the edge when I am turning rpm . I think full charge is around 4-6k
BIG PROPS !!!! To @KRUISR . Thank you for this find and saving me 100 bucks on having one made .
Left to right
94-95 Gt , 96-98 V6 , ford contour .
Reactions: 3 users
Glad to help. I always look to other OEM parts before I consider having something made. The hunt is fun and very satisfying when you figure out another way to do something.
Yeah man , I wouldn’t have known how to go about it the way you did but it is really appreciated . The only crazy part here is the pulley is no longer made so they are scarce
